Amazon MAF sensor
Flyhigh
As some of you know, I somehow damaged my MAF while replacing the TMM. After everything was re-installed the car threw a P0104 code. Idle was rough at best and half the time the car wouldn't start at all.
I was quoted $288 from the dealer for a new OEM MAF replacement. Edge sells them currently for $221.33 (also OEM). I know most wouldn't want to gamble with the MAF in our cars, but I took the chance and spent $35 on Amazon
This part fixed the problem and saved me a ton. Its been in the car for several hundred miles without issue.
You should probably edit OP and let everybody know exactly what the problem was that it fixed as well, just for others who might be looking at one of these to fix a similar problem to yours.
Also, those links don't work.
Done, thanks. The pics were unnecessary and unimpressive. Links removed.
Low these many years later, does your opinion still hold that this MAF sensor is okay for $38?
