Bought the speed last August. I was so excited. Then randomly I started getting overboost issues nonstop, which is super great when you drive on the highway every day. It got to the point where I'd overboost just leaving my driveway and driving 17mph in my neighborhood.
So... After digging into that overboost issue, not resolving it, and dealing with all the "kustom werk" done by the previous owner who, "knew everything about speeds", l decided to say screw it and swap motors and basically rebuild 80% of the car.
Currently car has been on jack stands since late November of last year. Finally got the engine bay cleared out enough to clean up and prep for primer/paint. Going to repaint the car. I'll be doing a hypershift paintjob on it.
Getting a stage 2 motor built from Damond and I have this laundry list of parts:
Installed:
Cobb AP
Sure Dreadnaught rear diff brace
TO BE INSTALLED:
Stage 2 Longblock
Manley HTuff rods
625+ head studs
Mahle 2618 pistons
King bearings
Upgraded valve springs for 8k rpm
Keyed crank
Will be installed as engine is put back in:
Grimspeed EBCS
Damond PS Cooler
Corksport HPFP (E85 Safe HPFP O-Ring Rebuild Kit)
Overspeed Injector Seals
Subframe Solid Aluminum Bushings
Steering Rack Solid Aluminum Bushings
Racing Beat Front Sway Bar
Whiteline 24mm Rear Sway Bar
AWR Front Endlinks
Godspeed Rear Toe Links
Firewall Brace - DTP
Circuit Werks 3" full exhaust system
Circuit Werks 3" Catless downpipe
CPe exhaust manifold
Fortune Auto 500 Series Coilovers
Split Second Controller
Injector Dynamics ID1050X Injectors
Fore Innovations -6 PTFE Fuel Line
JMF V2 Port Injection Intake Manifold
Treadstone TR1035 FMIC
WOT Box
Damond Dual Oil Catch Can Kit
Damond PCV Plate
Techna-Fit Stainless Brake and Clutch cables
ACT HD/Race Sprung 6 Pad Clutch Kit, Streetlite Flywheel
Damond Motorsports ARP Flywheel Bolts and Nord-Lock Washer Combo
Billet tcase caps - Damond
Rebuilt Tcase
AEM 320LPH Fuel Pump Ethanol
Vacuum Block
Brake Caliper Bushings - Damond
BNR S5 Turbocharger
Tial 44mm wastegate
Damond Motor Mount full set
3.5" HTP Intake
Bosch 3.5" bar map sensor
EBC USR Slotted Rotors
G-LOC Brake Pads
Throttle Body Spacer
GFB TMS Respons Blow Off Valve Kit
CX Racing Intercooler Piping Kit
MPS Auto Injector Stud Kit
Short Throw Shifter kit
Oil Temperature and Pressure Gauge Adapter Plate - Corksport
EGR Delete Block - Damond
Treadstone Crash Bar
Wire tucks
DI Harness
Coil Harness
SSC Adapter
SSC Plug
MAP adapter
New water pump
New AC Compressor
New Radiator
New Condenser
New front DTA axles
New Starter
Cleaned/Flowtested Injectors - CW Turbochargers
Graveyard Returnless PI setup
New Clutch Master Cylinder
Mazdaspeed6 Upgraded Slave Kit - xspeedfab
AC Line tuck - Racethetix
Coil Pack Rotation plate - Racethetix
Coil Pack Cover - Racethetix
Water Block - Damond
Route lines for GlowShift gauges:
Volt Gauge
Pyrometer EGT Gauge
Dual Intake Temp Gauge
Oil Pressure Gauge
Narrowband AFR Gauge
Boost Gauge
I'll probably recirculate my dumptube into the downpipe. I can't think of anything else, but I'm probably missing something.
Once all that's installed, I'll toss it on the dyno at Graham Rahal Performance and work with them and Damond to get the tune complete.
After all that's done, it's onto the interior:
Yanked the regular stereo and bought a fancy Chinesium Tesla style radio from the reputable dealer AliExpress. Sound didn't work from that so.... Replacing all the speakers (JBL studio), yanking out the bose sub, speakers and amp, probably do the speed3 seat swap, wash the carpet out, rewire all the speakers, two amps, one for speakers, one for sub. I'll probably try to find a way to fab in the sub in a way that doesn't eat my trunk space. I'll be doing a 360 camera install, getting Terlizzi headlights, Morimoto fogs, and I have a set of V3 LED taillights to install.
Bodywork:
Pretty gnarly rust, as per usual, on the driver side rear quarter. Bought a patch panel for that. Bought a parts car for a few other things like a replacement driver side rear door and a few other items. Then fix the random dents. Once the body work is complete, then I can do paint and wheels. I haven't decided on the wheels yet, but I'll have plenty of time between now and then to figure that out. I also ordered a SRT style CF hood, but I presume the car will be finished before that actually gets shipped to me, which is fine. Haven't decided on what kind of side skirts, front lip, or diffuser I want to go with. I'll figure it out before painting.
