AWD Speed 3 Project - Halfmilespeed3
Continued update so each post isn't too overwhelming.
- IMG_3828: I knew the front section of the spare tire tub needed to be trimmed and I knew that I wanted very easy access later on so i opted to cut the entire spare tire tub out of the chassis. This may not be the goal for others, but in my racecar specific case, it was the best path for me and will affect overall weight changes.
- IMG_3829: Here is a top view of the MS3 complete rear sub assembly (top) vs the CX7 complete sub assembly (bottom). They are facing opposite directions so I could better line them up and compare.
I can confirm a few things that i had been told before starting this project:
1) The 6 chassis mounting holes are in the same location and widths
2) To the best of my ability I could confirm that the inboard pivot locations for the lower control arm, camber arm and toe arm are in the same locations
3) The brake systems are complete different:
- The MS3 is a solid disc with the parking brake incorporated into the normal brake caliper. This is a simple and typical system.
- The CX7 is a vented disc (which is better) but the parking brake is a drum brake that resides inside the rotor have of the disc rotor. i've seen this system on bigger 3/4 and 1 ton pickups (my 04' Dodge uses this system). Its a PITA to deal with, is complicated and expensive. Not idea for racecar so I was not enthused to use that system.
4) The trailing arm/assembly:
- The MS3 visually appears to have a longer trailing arm section but measurements say otherwise. Its also a much less complex and lighter duty design. this is expected as its not AWD and it was not designed for an SUV from the factory.
- Likewise, the CX7 appears shorter but measures the same. I think this is due to the beefier design. The arm design also has less "swan neck curve" to it which may prove to be an issue.
5) Control arm lengths: All the CX7 control arms are longer. Track width of the MS3 is 60" rear whereas CX7 is ~64" so this makes sense.
So now let's mock it up and see:
Don't mid the high stance, I did not remove the OEM springs from the CX7 subframe. This would jsut an initial mock up to verify everything bolts in.
- Confirmed the subframe just bolts right in...kinda silly to be honest.
- As you can see, the track width is too wide...I'd say 2" to wide on each side...BUT this could be a very viable solution for anyone looking to do a legit wide body kit and not just using wheel spacers. (My gut says you could do this is a FWD fashion also, jsut using the CX7 control arms).
- Wheel centering in the fender arch looks good so I think we are on the right track.
so which is a better option to go with/ cx7 rear subframe and diff or ms6 rear and diff?
Loving the updates and the very well documented steps of this build. This could be huge for the high hp guys in the future. Maybe even some CS AWD future components like S1 for Hondas. ;)
I agree s1 has changed the awd drive game for Honda so corksport has been Mazda community go to for parts and would be huge for mazdaspeed platform
I'm not going to lie...the thought has been bouncing around in my head but looking at what has been needed so far and what I expect in the future...there isn't alot that is truly one-off.
- RMM for Speed 6 trans in MS3 subframe
- Could do diff mounts for the CX7 (technically not required though)
- AWD Controller (but this is more about splicing an OEM unit into the car)
- Driveshafts and Axleshafts (I will be inquiring with DSS for those)
- Rear dampers since they need to be shorter to clear the axleshaft (Speed 3 spring setups appear to work fine)
With that said...people do love a turn-key one-stop shop option so who knows. Would most likely have to be a group buy with deposit so people are committed. AND said person would still need to source some OEM components on their own (Trans, T-Case, CX7 Subframe and Diff at a minimum)
a group buy for the custom parts is the way the go to tet the waters but knowing the mazdaspeed community the demand will will be be crazy high. the awd drive swap has been a need for this platform.
Possibly, but expecting my guess around $10K to buy because of the involvement of custom pieces. Let's watch the mad scientist do it on his Speed for now.
YOU CANNOT USE THE MS6 REAR SUBFRAME...you might aswell jsut fab your own subframe at that point.
The easy solution: Use the CX7 subframe (the inner frame work that bolts to the chassis only). Then use the control arms and trailing arm from your MS3. The rear differential is made up of two sections (the front section holds the clutch pack and the rear section is the gear housing). Externally, the rear section is the same between the MS6 and CX7. The internals are different; LSD vs Open , respectively. The front section is different externally. The MS6 uses a one-sided mounting setup vs the CX7 using a symmetrical two side mounting setup. To bolt directly into the CX7 subframe, you need to use the CX7 front clutch pack section.
NOTE: the differential mounts for the CX7 are unique (fronts and rear) vs the MS6. I am designing my own billet mounts. You may be able to use the CX7 mounts and replace the OEM rubber bushings with poly bushings...?
Honestly, the axles are the biggest ticket items (especially depending on what power level you want to support). Most of the parts are OEM (junkyard sourced for CX7) with just some supporting custom billet parts and rear suspension support.
Now the "tuning" for the rear diff is a whole different story. OEM ECU vs Motec ECU makes a huge difference and how much control you want. I want full programmable control so I'm going full custom setup. Working in tandem with the Motec, I am investigating a standalone controller from Syvecs that can take in many inputs (4x wheel speed, diff oil temp, throttle plate angle, accel pedal percent, etc...) so that I can tune and create control algorithms for the AWD system. IDK how much the controller is yet, but my guess is around $1000.
Progress Updates...1 of 3 of them!
Firstly, I got my rear trailing arms back from the machine shop. Look pretty good and fit great with the CX7 bearing hubs.
They welded the original holes then post machined the new holes for the CX7 bearing hub.
On the back side you see that the "cutout" for the steel stamping fits the original and the new CX7 bearing hub bolt pattern inside the cutout. This makes me thing the stamping is a more universal part but the steel plate welded to the stamping that has the bolt pattern is unique to use different brakes and hub for the mazda 3. Seems silly but I bet it saved Mazda money.
Lastly, the machine shop pocket machined the back side so the hardware has a flat consistent surface to clamp against.
trailing arms came out nice and looks great
i appreciate the detailed information and you sharing your build with the community. keep up the good work on your build
Progress Update...2 of 3
With the rear arms done, I could reinstall the arms and bearings to get my rear axle lengths.
In doing this I had to make sure I was using proper surfaces to base my lengths from.
Differential Side:
View attachment 24527 Measuring off the face of the seal that is more of a face vs the flared cone part of the seal that you can see. I'll be sending this image to DSS with my order.
Suspension Side:
View attachment 24529 Measuring off the large inner face of the bearing. Again I will be sending this image to DSS.
I wanted to also verify that CX7 and MS6 interchange so I measured the OEM shafts for each and installed the CX7 bearing hub onto the MS6 axles.
MS6:
View attachment 24530 View attachment 24531 View attachment 24532
CX7:
View attachment 24533 View attachment 24534 View attachment 24535
I would say they are the same and when installed they feel/act the same. So this is good news as I know DSS has all the data for the MS6 fitment.
that's great that the MS6 axle fits the cx7 hub and vice versa. find an axle with the correct left will be the only thing that would be require.
let us know the left with dss axle comes back
Another update:
Transmission is still in progress. Have had some difficulties with shims and such, getting the bearing preload setup. If you are doing any trans work or differential change be warned that Mazda is discontinuing the various thickness shims needed for the bearing races. I ordered what I could and also made my own in various thicknesses. Essential stacking thin shims to get to the spec I needed.
This was needed for the Damond LSD especially (nothing wrong with the Damond LSD, but when you are talking 0.002" differences to get bearing preload correct...things are different from one to another)
Shims I designed and had cut by SendCutSend
Per the service manual; There is a torque spec for bearing load of the differential alone then the differential plus the 5/6/R secondary shaft.
I made my own tool to turn the differential as shown with an old axle shaft end and socket welded to it.
Another Update:
Rear axles from DSS arrived.
These are "700hp" rated axles per DSS. Doggo approved
Axle fitment is good with lots of length adjustment range for more or less camber than the current -2.5 degrees.
I also opted to have the wheel speed rings placed on the inboard side of the axles so i don't have to fight fitting a speed sensor inside/through the MS3 trailing arms. I will make brackets off of the rear diff mount to mount the speed sensors.
I have ordered speed6 wheels speed sensors for the rear. I will need to change the electrical connector though. It seems the MS3 is unique in its design vs the speed6 and CX7.
The blue part is the final design for the CX7 front diff mounts. Those are in machining now and I should have them in a couple weeks.
About those DSS rear axles...
The shaft diameters are different for left and right...this is not by design.
I talked to DSS about this...basically they said its fine and they used what they had available on the shelf from older MS6 production (yes that also means the MS6 rear axles have varied in diameter)...I'm not stoked about it but I need to keep moving forward with the project. They fit well otherwise.
If the axles are rated to 700 I doubt the diameter will make a difference since I doubt the rear diff can take 1400 hp but knowing they were different would drive me nuts
Ya thats my same logic.
Touching on the power capacity of the rear diff system...I have more hope. Newer cars with this front biased AWD system are using a simple but clever way to be able to apply more than 50% torque to the rear wheels. The rear differential ratio is ~0.7% higher than the front differential. This creates a speed difference that the rear diff clutch pack can take advantage of. Locking the clutch pack 100% results in more than 50% torque going to the rear because of the speed/gearing difference. However, most of the time the clutch pack is not 100% engaged so there is some amount of slippage in the clutch pack happening. This is great from a torque biasing standpoint but the by-product is excessive heat build up...which we've all seen issues reported of such in the Focus RS and Yaris GR.
The Speed6 can only transfer up to 50% of torque to the rear wheels (unless the fronts have no traction which is unlikely) because the differential gear ratios are the same front and rear. This is good because the differential clutch pack can be locked 100% (and is most of the time anyways from the factory) so the heat issue is reduced significantly which will help with strength to some degree.
Yea I can't imaging the heat from burning the clutch on the rear diff all the time
i think a custom trailer arms and axles would be a good DIY kit to start with which would help customer's
UPDATE!
The front mount for the CX7 arrived and look fantastic! Everything fits perfect (not tested on car yet) but I forgot to order the correct length shoulder bolts so I'm ordering now and will have monday.
Today I also worked out my design for the push-rod mount on the trailing arm. This was a little tricky to find the right angles, tire clearance, and clear the brake line and parking brake cable. Over it looks pretty stout and checks the boxes. Ordering steel parts today.
Did some very basic "eyeballing" to check feasibility then got some measurements to CAD up a design and 3D print.
CAD Models (this is the final version)
3D Prints (first version)
I'm not showing some of the iterations I made to the prints but you get the idea. I had to play around with the push rod angles to find a sweet spot. At full droop vs full bump, the angle of the push rod changes alot due to the trailing arms arch when it swings up. So I moved the bracket further reward and added some angle so that ride height and full bump have more neutral angles.
So with the design, I am depending on the weld strength and the mechanical strength of the joint.
And here you can see the brake lines clearance.
Lastly checking tire clearance to the push rod and to the fender...everything is tight but fits!
I did end up moving the bolt pivot location inboard an extra 0.25" incase i want more tire width later on.
Things are starting to happen! It actually has a transmission now!
Trans and T-case went in pretty smooth. Intermediate shaft and mounting block are also in. Looks Great.
The oil drain is also very tight but good. I thought ahead with the Xona turbo install and got a oil drain setup that would work.
I bought the flange and lower 90deg elbow from Eric and used a 90deg AN female/female fitting to attach to the Xona provided -10 AN flax drain. Its been working great and is easy to disconnect.
With the transmission and t-case in the car I could put the subframe in and start working on the RMM to connect MS6 trans to MS3 subframe. Here you can see the CS Stage 2 RMM mounted to the subframe. I got it as parallel and possible to the trans and took some measurements. I am going to use the same general design as the CS Stage 2 RMM because it works so well and is easy to adjsut the design.
I have the design 3D printing right now for test fitment.
Lastly, front driveshafts:
Driver Front: confirmed the DSS 5.9 fits perfectly. No changes needed (I would assume OEM will also fit)
Passenger Front: The MS6 intermediate shaft uses a larger 30 spline male shaft vs the MS3 28 spline male shaft. DSS does not have the 30 spline inboard CV housing so they asked me to send an OEM MS6 inboard housing that they are going to modify to work with my DSS 5.9 passenger CV axle. That shipped out today.
MS6: IMG_5031.JPG
MS3: IMG_5030.JPG
The turbo oil drain plumbing looks great!
My current drain is bent up stock piping, will likely fail. Now I see a option to replace it with. It is pia to get access to remove or correct with transfer case in place from below. I don't have a pressure oil nozzle filler so make sure Transfer case oil is done, I was a idiot thinking had to have axles in place before, found oil level is below axle half shafts.
Learned my lesson on second install in my 6.
Thank you for your efforts to show us how it can be done.
MS6: View attachment 24937
MS3: View attachment 24938
Thanks for the update.....glad to see the progress is coming along awesome stuff.
my question would be for the MS3 driver side motor mount, does it bolt right up to the MS6 trans? and Retain the MS3 shiffter cables?
