I also worked on alot of electrical and fuel plumbing recently:
Electrical:
So I moved the battery location to passenger side in front of the rear axle centerline. This did not requirement to change my cables much and helps with weight distribution a bit more being passenger side.
The AntiGravity Battery can be mounted in any orientation which helped alot and the MELE box is solid so its bolted directly to the chassis.
You can also see here, my rear mounted fuse/relay box so it also gets power directly from the battery and will power the entire fuel system and Syvecs AWD controller in the back of the car. The OEM "signal" for the OEM fuel lift pump will "signal" the relays for each pump:
- 525LPH lift pump inside the cell filling the surge tank which feeds two external pumps
- 380LPH inline 044 style pump feeding DI only
- 525LPH geared MagnaFuel pump feeding the PI only
So this way the entire system is on/off by control of the Motec and on one leading circuit with each getting their own dedicated 20amp relay
I also added in a rear exterior kill switch to meet NHRA requirements. This did require some changes/additions to my cables and such. I had to get a little creative making "T" splice with 2awg cable. Overall it came out very nice, dare I say OEM level on that splice.
Now to the fuel system plumbing. Both external pump are under the chassis floorboard where the OEM fuel tank was previously sitting.
- MagnaFuel 525 driver side with dedicated 10AN feed line then feeding a 10AN hardline that comes up into the engine bay. There is also a parallel 8AN hardline for the PI return that returns directly into the surge tank.
- Quantum 380 passenger side with a dedicated 10AN feed line that is plumbed into the OEM hardline feeding the HPFP.
I am well aware of how open and vulnerable everything is. Both pumps are quite high up but exposed to the elements and the driveshaft. I plan to create a driveshaft shield to protect the pumps and hard lines. A later down the road flat bottom aero will add more protection.
Next are the hard lines in the engine bay. I'll admit this is a little more haphazard than I would prefer but I am running out of time. They are secure, isolated, and easy to access with everything in the engine bay.
Lastly is the fuel cell setup. With the pumps located I was able to setup the bulkhead fittings and plump the two feeds and one return line.
The fill hose is also cut to length. The filler neck will get secured once a mounting plate shows up.
