Mazdaspeed 2012 bought from car max with 70k miles on it. Put about 25k miles on it so far so I’mat 96k miles right now. Bone stock up until now with added mods listed done around the 90k miles mark.
Before it was heavily modded, on one day about a year and a half ago I was driving and pulled up to the gas station to check hot oil level waited about 5-10min for oil to drop down to oil pan checked oil and it was below the min mark at the bottom of the dipstick. Panicked, I rushed doing research and misread a couple forums of the dip stick being hard to read whatever so I just sent it. After some learning I realized I was driving on low oil until the I did next oil change and I was stupid to dismiss it and could have done some severe engine damage.
So the past 2 oil changes i have kept tabs on the oil level. I no longer drive it as a daily since I have a work truck. It consumes about half a quart every 500-600 miles. Given that it’s been doing this before and after mods aka oil catch can/oil restriction banjo bolt and no heavy blue gray smoke coming from the exhaust like at all even with cat-less I don’t think it’s turbo seals I also check the OCC every 1,000 miles and I get about less than a 1/4 of oil out of it when draining it. I had the down pipe off and inside of the turbo on exhaust side just looked like black soot. Compressor side of turbo and turbo inlet pipe had but a slight film of oil but not enough to create a drop of oil. When I was removing the cats and upgrading the down pipe I did not see any visible leaks as well. Spark plugs seemed fine just your normal wear and tear no oil deposits. So my educated guess with my compression test being 180-180-175-180 that it could be clogged oil control rings besides a cracked head gasket and a b12 soak would be a good step to take and puttin in some thicker wieght oil.
On that note I’ve read and watched YouTube videos on doing a 24 hour b12 soak and I’m a little confused on the procedure.
When starting out, do the valves need to be level with each other or that doesn’t matter just pour b12 in? And how much b12 do I pour in each cylinder?
Do I need to crank the engine by hand when turning the valves over after it soaks every 6 hours or can I crank it with the key in the ignition with spark plugs removed of course? Do I leave spark plugs in while they soak?
After soaking process do I let it idle for 20 min and go for a 20 min drive then change oil? After how long do I change oil again to make sure all the contaminated oil with b12 is flushed out?
Pictures below are before and after 500 mile of driving hot oil level check.
mods-
.Grimmspeed EBCS 3 port mode.
.Injectors Cleaned by RX injectors before tuning process began.
.Valves soaked and cleaned with b12 and vaccumed before tubing began.
3" Exhaust Cat back titanium tips -ULTIMATERACING
. EGR Delete w/ block of plate -DAMONDMOTORSPORTS
. Oil Catch Can vta- DAMONDMOTORSPORT
. High-pressure Fuel Pump Internals/e85 gasket kit combo -CORKSPORT
. Spark plug replaced/ LTR6BHX .26 gap -AUTOZONE
. Turbo Oil Restrictor bolt -DAMONDMOTORSPORTS
.PCV plate upgrade -DAMONDMOTORSPORTS
. Rear motor mount -DAMONDMOTORSPORTS
. Dual VTA Bypass Valve -CORKSPORT
. 3.5” Downpipe cat-less -CORKSPORT
. 3.5-inch Mazdaspeed 3 Power Series Intake System -CORKSPORT
. TMIC Top Mount Intercooler -CORKSPORT
.VCTS deleted completely plugged intake manifold hole.
.Software using Versatuner/Damond tuned
.oil pennzoil 5w-30
.Corksport injector seals installed
.Compression 180,180,175,180 after new injector seals
mods-
.oil pennzoil 5w-30
