You are intending to final these out of metal? Have you considered using some pipe insulation to bridge the gap between the ducting plate thing and whatever it is interfacing with? Gets you the nice rigidity of metal, with the squishiness of foam for closeout.
Do you have your under tray for the car? That thing will make more difference in bats then any diy ducting. Without the under tray you will have cooling issues come summer on track.
with the under tray and ducting you will be happy.
A full oem under tray is all you would need. Nothing fancy unless you’re making 500whp and intend to run 20 minute sessions balls to the wall.I have the frontal part that goes directly below the IC and radiator attached to the bumper, the tray I have is loosy goosey at best. I'd imagine the full undertray would probably help, but I figure for $0 in free scrap metal, I can evaluate if its worth getting a full metal or just OEM undertray later on in the year.
Corksport had a metal undertray that's great, you could very easily make something like that if you have access to free scrap. I'd love a.metal one of keep breaking mine in the winter...
Really you just need the OEM plastic parts that shield the wheel wells that it bolts too at the back and then you should be good to go.
You can totally build the side peices just less fab work plus plastic break away has its benefits to break away.Would be cool to build an undertray, I might actually give that a shot...
Also If I don't build these cool side things how am I going to simp for scene points?
Awesome, please post pics unistalled and installedActually got them made yesterday, took about 10 minutes per piece, but I forgot them at my Dad's shop, so I'll need to go grab them later this week.
Bolted on my new rt660’s lastnight. Initial impressions from the street, they are unbelievably sticky right out of the driveway. More grip comes with a little warm up. They are much grippier then my re71’s were. Can’t wait to test them out on track.
I can tell tire temp management will be important. A soft tire like this will probably overheat quicker then say an rs4.
those look to be 500 series. 510’s are a different color and I’ve yet to see anyone go as far as 510’s for a ms3. They are nice though. Ask me how I know lol.
Any clue on what the spring rates are? Those will do a lot for your car.They honestly ride just as nice on the street as my old CS Shock/Eibach spring kit did, but without that wallowing feel from the springs. Very pleased so far, and quality is top notch.
