Got the piping together and oil temp gauge fully wired up. For anyone using the new version of CXRacing piping, this is what you will need to complete it:
*Straight Coupler you can cut to size-
Amazon.com: TMKOOL 8" Length 4-Ply Reinforced High Temp 2.5" ID Straight Coupler Silicone Hose (BLACK, 2.5'') : Automotive
*U-Pipe -
Amazon.com: Ucreative 90 Degree Elbow 4-Ply High Performance Coupler Silicone Hose 2.0 inch to 2.5 inch (51MM to 63MM) : Automotive
*90-degree reduce from turbo to pipe -
Amazon.com: AotoKoop Aluminum Pipe L 11.81" (300mm), OD 2.5" (63mm) Universal 180 Degree Aluminum Piping Tube Intercooler Pipe Polished U Bend Aluminum Air Intake Tube, for Direct Replacement of Engine Bay Pipes : Everything Else
*Straight pipe for over the HPFP -
2.5 Inch OD 5 Inch Long Aluminum Joiner Pipe for Intecooler turbo (amazon.com)
Car started up great, but pops codes for VTCS, EGR, and Knock sensor. Sounds really good at least.
The P0328 code presents itself in my case as 1.05 knock at any throttle position except none, even just a barely light tap at idle, and not changing at steady throttle. Took it about 2 miles around the block a few times, no dice. I was able to get up underneath the manifold and tighten it down as far as it can go, but it still presents symptoms. I pulled the knock sensor, pictures below, and can't see anything that would indicate the wires are damaged or the harness connector is bunk. Both sides look fine from the sensor to the main harness.
Would there be anywhere else that may be causing it to pop? The sensor wasn't moved at all during installation, I only routed the harness up and behind the fuel rail, not pinched anywhere. I have a new used sensor on the way, we'll see if that fixes it.
View attachment 24656 View attachment 24657 View attachment 24658 View attachment 24659
