Brakes making a squeaking and grinding noise.
Gandalf
I don't have a clue as to what's going on with my brakes, they are squealing and making a grinding sound. I pulled the pads and it looks as though I should be able to get another 30k out of them , there must be something else wrong, any ideas?20160605_171007.jpg
Something similar happened to me once too, rear caliper. One pad worn down to metal while other was at 90%
Root cause: sticking sliders. My guess is that shop used grease that made slider's rubber sleeve to expand.
We are going to need to have datalogs. Do you have a VersaTuner, Accessport, or still running the CPE Standback?
Low fog light fluid would most definitely cause this. If that doesn't fix it, check your seat horn emergency release button. It's in the gas tank door.
@Rokusek will this work?
tapatalk, it sucks
New EBC yellows with freshly cleaned rotors installed on the car today. I haven't taken the car out yet, thinking I'm going to change the brake fluid also. I have ATE Super blue in the car now which isn't available anymore but it's basically the same as their 200 so I'll grab some unless y'all can guide me to something better. I don't need all out track fluid and don't have issues changing the fluid every year, I have a Motive power bleeder.
