The goal is to go faster so work from the new setup to make it feel like you want dont work back towards the old setup. If you had the front at a good height then raise the rear. You can be too low and outside of the optimal range for the suspension
Yea so part of my problem is the new springs gaining me a half inch of ride height up front.The goal is to go faster so work from the new setup to make it feel like you want dont work back towards the old setup. If you had the front at a good height then raise the rear. You can be too low and outside of the optimal range for the suspension
Tire wear. 5 events. One of them kinda wet. This is with 3 days on the old front springs and 2 on the new. I swap the left and right tires around to even wearA thought... If you went softer with the front spring, could you go with a stiffer front bar to combat the body roll? This would let you get more weight transfer on to the front.
How does the tire wear look? Can you play with camber.
100%. Sometimes I wanna quit for sure. It’s such a fight some days but I must say when the cars good…fuck. It’s good. Makes it all worth it. The support has been fantastic too that is for sure.You've made it this far, past several obstacles, and now have been lots of love and support. Don't turn into a pussy now.
I think it seems reasonable. There’s a gridlife GLTC guy, Eric Kutil. Races a civic that’s way too dialed in. We’re talking pro stuff. Adjustable everything. He uses the rear ride height to adjust the cars attitude. More turn or less turn just buy raising or lowering the rear a few mm. He says it’s more fine tuning vs the sway bar, then you also have the sway bar as well. A mm or two of rake makes a pretty noticeable difference. I can say that myself for sureYour idea is how I would proceed also.
This. The weight transfer was huge with the old springs. I could really feel the front end roll while the rear end stayed completely flat. it was an interesting feeling but the front end was biting hard. Felt great under braking, turn in, trail braking. With the new springs i lost that dig, even on the brakes the car doesn't care. it doesnt even brake as well now eitherIt sounds like you were getting more weight transfer on the front with the sagged out front springs.
There's no data to see in the front tires since they have been on both setups.. We can't see any differences.
I dont pay full beans for my multiple yearly alignments. For the front end which is what we usually mess with, ~125$, if its gotta go on the scales, around 200-250Unless you are getting a sweet deal you should really learn how to do your own alignments
It was yup. I went faster than him in straight up raw time but the stupid pax system fucked me and he gets first place cause he’s got less pips than me. AnnoyingWas first place the cheating frs
