That is a sweet rig for sure. Price seems low to me
He had it listed for higher. Has since dropped the price. It’s 11,500cad which seems to be inline with other trucks of this year. This one is just exceptionally clean. People just aren’t buying these big older SUVs I guess. I know it ain’t great on gas lolThat is a sweet rig for sure. Price seems low to me
100% yes lol. People think using a lot of brakes means you’re fast. It’s literally the oppositeSmooth is fast and with all that power you aren't making you can't afford to use the brakes
Based on virtual dyno peak power at 8800rpm is the same but 4000-6000 is night and day. The built motor was a total killer in the midrange. That would be my corner exit specially out of these slower corners.Kudos for driver mod. What's the power difference between now and the built motor?
The guy tried to pull a fast one and raised the price on me after he had to spend a few bucks on certification. Our deal was asking price certified. Not a dollar more. I walked.Did you end up buying the Tahoe? I highly recommend getting HPTuners right away and disabling DoD and tuning the 6L80. There are a lot of small improvements that can be had by just doing those.
I used software called BC Trans to adjust the tables for mine. Pretty easy to use. I can also email you my old 2011 Silverado tune for you to use as a reference.
Great info thank you for this. If and when I do get the Tahoe this has got to be first on the listYou can disable the DoD system through the computer and ideally install non DoD lifters. However just turning the system off in the ECU drops the failure percentage by at least 80 to 90 percent.
I disabled mine with just the computer and never had any problems. The issue comes down to when the lifters need to un latch. The get stuck and that's when they need replacement. If they dont ever latch then they probably wont fail.
A new camshaft is required when installing non DoD lifters because the duration is different on those cylinders.
