gotovato
There are some chinese manifolds that suck for sure. That much i know lol. I also forgot to mention the resonance RPMs the skunk2 makes vs the stock stuff. the skunk2 manifold when mathed out does show the gains as i metioned from 7800 onward. Nothing factory will touch this. Even ported. Youre still dealing with the same plenum volume and runner length. These manifolds can only be ported so much, and that generally only impacts flow and not where the manifold makes power(resonances).There may be some bias on my end, I've seen a fair share of those $100 Chinese manifolds fail. Actually just saw one on FB today lol. But you're definitely right that a larger plenum will have gains at the high end.
RPM and piston speed. Reliability. Definitely not a factor of peak power at all. that doesnt matter here. just the rpm, piston speed, overall duty cycle of the setup.Nothing wrong with building in a larger safety factor, many guys buy 625+ bolts because someone told them to without a reason why.
This is the surface level view of 4P. Dive into the k20a forums and youll find too many examples of their engines being junk, their advice being either drag specific or just wrong. how can a 15,000$ engine spec'd to make 330hp crank, only make 270crank when the customer receives it? its not just one example either. Then factor in after 20 hours of usage the cylinder walls are so bad the engine is smoking? again. Drag vs Road course. That engine would probably give 2-3 seasons on the drag strip. Poor guy didnt even get 1 season on the road course. There is more to this but no point getting into it its whatever. I initially was a huge 4P fan until i learned the ugly truths. Its out there just gets buried.4P is a great source of info IMO. I've talked with Luke before, they do a ton of road race K series for both private customers as well as race teams. They 100% know their stuff, they just advertise the drag stuff WAAYY more because that's a much bigger pie to make money off of and they're a business so it's just sensible marketing on their part. Believe me I'd love to see them start sharing more on road race engines.
regardless of piston technology changing, if you are using a stock k24a with its cast pistons, which wouldve received 0 upgrades as its been sitting in a scrap yard for probably 10 years....you will not have extended success revving one of those past 7800rpm. this is well documented on k20a forums. Same goes for a k20z exceeding 8600rpm. For endurance events, back when this generation was being raced by honda, there was heavy testing. at 8300rpm, a k20z3 will last 80+ hours in an endurance environment.None of the guys I'm referring to are in ASM. It's mostly ClubTR guys that are required to run stock engines and DE guys that just want a simple package. I generally see more bearing failures than anything else. Take piston speeds with a grain of salt. Yes, there are speeds that shouldn't be exceeded but those recommended numbers have been largely unchanged for the past 3-4 decades and piston technology has come a long way since then. It's hard to compare piston speeds in F1 engines because they are limiting it for a few reasons, one being that their rules limit engine speed as well as displacement. Beyond a certain speed you start getting into ring sealing issues too, which is amplified by shorter skirts and single compression rings (which F1 engines both utilize).
At 8600 rpm, 40 hours. At 9000rpm, maybe 1 hour. The failure was a piston just exploding. The second it expands enough to even partially seize, thats it. Youre going to rip the pin right out of the piston. Or destroy a rod bolt. either way its total failure. This is with an 86mm stroke. A 99mm stroke? Well theres a reason honda didint race those. Ever. Even funny that to make a k24 good it requires k20 parts lol. It serves its purpose i wont argue that. K24 is awesome for sure. Its just not what im interested in at this time.
more stroke, only slightly longer rod, more side load. Then crank up the RPM and the side load increases. On a built motor with nice clearances maybe its not so bad but stock bottom end, add in some piston expansion and you can see where im going with this. youll destroy the walls. Rods bearings as well as you noted.Side loading is mostly influenced by rod ratio, and things don't wear things out as fast as you'd think just from having a low rod ratio. You'd be surprised at how many engines that are notorious for being high revving engines (factory redline of 8000 or higher) actually have low (sub 1.7) rod ratios. BMW S54 (1.527), Lambo 5.2 V10 (1.659), Ford 5.2L Voodoo (1.613), Honda F22C (1.653). The reality is the rod ratio isn't all that different between the K20 and K24, mainly because the K24 block has an almost 20mm taller deck height, which means the considerable increase in displacement comes at a fairly small penalty on the rod ratio, K24 (1.535) vs K20 (1.616).
lol. yes and no. ill argue this. My honda makes WAY less power then my speed ever did. WAY less power then that GT4 Porsche i was inside of lap after lap. Power matters almost nothing if you cant drive. so no. more power is not more fast.That is how you go faster lol. Horsepower is just torque over time, more torque means more power under the curve (insert "no replacement for displacement" boomer message here lol). More tire isn't a bad thing either.
USING more of the car is more fast. if you can use more of the power, sure. If youre limited on tire size or compound then it doesnt matter. people often think theyve maxed out their cars and need more power or tire or suspension. Spending money is way easier then learning. It just is. 99% of the time its that they simply need to learn something new. Learn how to better use the tool you have instead of buying more tools and having no idea how to use them. This is huge in north america as you know. there are civics with sub 900hp holding records against cars with WAY over 1000hp. they have tried to grab those records and nothing. guess power isnt the answer? maybe im wrong but from what ive learned myself, i dont think so. Spend enough time at the track which im sure you have, and this becomes clear as day.
Torque over rpm is where the k20 shines lol. kinda the entire point of this build. Even if its 170wtorque, at 9300rpm...thats a little spicier then 190tq at 8000rpm, which will be a hell of a build to hold that torque at that rpm in a k24. its not a massive difference no, but again, as you rev out that k20 its just moving into its power band, each shift landing in the meat, revving towards more meat. a k24 is moving away from its power band.
Yea ive noticed this. Im lucky my guy over on the k20a forums has the cam stuff down to a science. My current "cam of choice" is extremely spicy. Toda has however answered all of my questions so far and are extremely excited for results. This aint no grocery shopping camshaft. I may be the first in Canada with it. One of the only in north america. Japanese just do things differently you know? they get it.You're right, it all goes back to area under the curve. Camshaft ramp rates play a huge role in that but it's not something that can easily be put on paper, nor do any cam companies want to share that lol.
haha yes. that is for sure! to think the initial plan was to build a boosted k20. Due to budget those plans changed. This build is by no means inexpensive, but it does work out to be a good chunk less then the turbo build i had planned out!Regardless of how it works out it'll make for a good case study and solid learning experience!
