That screenshot of the datalog was from a WOT 4th gear pull. I'm okay with it cracking early at ~1790psi, but dropping into the 1400-1500s is where I start to get a bit concerned.That could be the PRV opening up just enough to let a *drop* of fuel out.
Edit: The camshaft runs at 1/2 crank RPM, has THREE lobes to drive the HPFP, and has VVT so who knows when it's going to push the piston forward or at what rate (faster if advancing, slower if retarding), etc.
Also assuming you were cranking it here, correct? If so, then the spill valve and check valve come into play; yet more variables. Get the car hot, in a controlled environment (where ambient is say 70-80F and then see how it acts. Other than that, even 1750 PSI you see here is actually fine.
I'll retry the PRV test on a hotter day and see if my results are different.
