How hard was it to do the gear swaps?
It really wasn't too bad it was just very time consuming especially doing it for the first time. Eventually I'll get around to making a write up for it. I took probably a hundred pictures easily during the disassembly and reassembly. Also I'm about to work on someone else's trans, replacing their shift forks and 2nd gear synchro.
[doublepost=1522942381][/doublepost]I have a pretty big post in terms of pictures AND progress. Finally received my 16wfab manifold, it looks gorgeous! Also this past weekend I finished up my trans and put it back together. The engine was wrapped up as well, we bolted the exhaust mani to it with the turbo and intake. Also began to hash out my fuel system. I missed a couple of items when I was ordering everything so we couldn't install it. I ended up ordering the wrong Vband clamp, I ordered the tubrine inlet instead of the turbine discharge by mistake. So I have that on order, I also had to order another 4 bar map sensor since I somehow misplaced my old one after I took it off the JMF that I sold.
There was one small issue that were going to be to iron out. Anthony didn't have any Bosch 2200CC injectors in the shop and couldn't get the info from Bosch on how tall the injectors were so the standoffs that he made were slightly too big. Not a huge deal, we can cut them down to size.
Here's a picture of my head gasket, had to get a custom one from Cometic because they didn't have one for 1/2" headstuds. They ended up going through 4 MLS head gaskets before deciding to go with the MLX material because they couldn't get the bolt holes lined up.
Here's the engine done and we started putting some of the accessories on.
Here's
@etipp98 helping me button up the trans
Done!
Lastly here's a pic of the Radium fuel basket that I ordered. I'm very happy with how it looks but I have one small issue that I didn't really notice before ordering it. The Evo X has a tank pressure sensor so I need to find something that plugs that hole before I can throw it in the tank, should be an easy fix. Oh and do all the wiring...
