Code Monkey
Silver Member
2006 Mazdaspeed6, 53k miles, bone stock, let the fun begin. Just ordered fuel pump internals....
Seeing these pictures makes me wish someone would make a full replacement shifter for the 6![]()
Maybe I could use Corksport's gen 1 shifter? I do not have to worry about the shifter fitting into the center console so if the mechanics are the same, using the shifter on the ms6 should be doable? @CorkSport - Derrick;
I was thinking more along the lines of the TWM full replacement.
Sleeper build with full roll cage and stripped interior I lubs it! What's the outside looking like.
You'd think I would, but I was really excited for an actual sleeper build
Question why white line over jbr for rsb
As long as the stud placement is the same it should work?
I dont have a speed6 here to look at. Get me a few close up pictures of yours and email them to me, Derrick(at)Corksport.com.Maybe I could use Corksport's gen 1 shifter? I do not have to worry about the shifter fitting into the center console so if the mechanics are the same, using the shifter on the ms6 should be doable? @CorkSport - Derrick;
Why the ETS TMIC as a FMIC? Why not a larger core?
