AYOUSTIN
That's interesting. It shouldn't stand any taller than the factory brackets. Must be the further forward placement of the one bracket plus the sharp corners.
Are you planning on making a different one completely or modifying the one you already made?
I think it's mostly a matter of the manifold slightly changing turbo position as well as the turbo being larger. I will modify the one I made, should only need to chop down one corner.
I can adjust the drawings if you end up letting me know what needs to be changed.
The corner that's further back on the bracket needs to get cut down. Not sure by how much or how to really account for it in a drawing without getting really technical.
