Ebay RESPONS TMS GFB Dual Port BOV - "EFB"
Haha sounds great. I'm gonna have to mod me one of those vent pods. That thing looks slick.
to be honest, i don't even pay attention to that boost gauge anymore since i monitor it on AP now, but yeah...i really love the look of it in there. i think RPM store is who sells those pods?
UPDATES: Have had this valve for a while now and still no issues. I have it set to full vent right now "catless" and I get a few pops but nothing dramatic. Car runs and idles great.
This valve shouldnt leak under boost. Same pressure is on bolth sides of the piston. Ok the way it leaks is at idle and part boost. If it leaks you get bucking when shifting, high idle trims and rich between shifts/backfire.
I have the real gfb but the knockoff operates the same. You can just recurc but if you feel extra lube me up gay you can do a reach around and turn that crown and get that hot psshhhhh all over your face. Drop panties and get laid by anything with a pussy in ear shot of the car.
I just use it when my wife drives my car since she is embarrased by the turbo sex sounds.
LMAO what did I just read, am I in a porno now?
I purchased and installed the ebay knock off GFB dual port from here http://www.ebay.com/itm/New-Mazdasp...ash=item4aefa1cf54:g:WvIAAOSwYHxWISBE&vxp=mtr I offered them 105$ and they took it.
I have been running this valve for 6 months with no issues at slightly higher than stock boost levels "VT OTS map".
I will include some pictures when I get more time. @SharksInSpace also owns this valve and got it for around 85$.
Quality - Looks good, adjuster is hard to turn but smooth. Trumpets are thinner metal but won't crush too easily. Valve looks like GFB looks to be machined well. Spring is heavy duty. Not sure if GFB whistle trumpet fits.
Install - Very straight forward install. I used their gasket as well with no issues. Remove the stock BOV and install this one. I had a longer vacumm line on hand and used that, can't recall if I for sure needed it.
Adjust - Once it was installed and set for about 50/50 vta I started to adjust it. I used that video as a reference.
Happiness - 10/10 sounds great and no issues at idle, even set for 100% vta I just get an occasional backfire but no idle issues.
Mine says xs power on it, @SharksInSpace got one without a decal and it was a little cheaper. It appears to be the same valve. He also took it apart to turn the vacumm port which I did not do and hopefully he can comment on this.
Sounds!!! - RICE RICE BABY! 35% VTA
Pics -
UPDATES!!!
The GFB Whistle Trumpet fits this valve. @SharksInSpace has included a video.
https://www.rallysportdirect.com/pa...-valve-whistling-trumpet-attachment-low-boost
Low boost attachment works well with this as you are not doing 100% vta.
gfb_5702_1
Hey what’s up Johnny, I just brought this bov but it didn’t come with the silver piece where the bypass valve hose could connect. Is that how yours came in or would I be missing that piece?
