Scaytale
Gold Member
ENGINE/DRIVABILITY
Updated to add link to video since it didn't seem to play when I tried to see it.
Surprised no one mentioned it.
Year/Make/Model: 2013 MazdaSpeed3
Mileage: 162217
Concern: Engine Noise, Timing chain? Cam advance? Something else?
This noise started on a test drive about 3 miles in after entering the freeway, not real loud on the road and I didn’t push the engine at all, this was going to be a test drive after getting the leak at the valve cover fixed (the head was cracked). This required replacing the head.
Prior to this, and after installing the 2.5 the Engine ran well and I was just starting the MAF calibration when it started leaking at the Valve cover, it took a long time to figure out it was the head and get a replacement. There is a post about my valve cover issue on the forum. https://mazdaspeeds.org/index.php?threads/valve-cover-oil-leak.16535/
once I got the new head on and ran the engine it seemed fine, no leaks good vacuum, took it for a short ride to make sure it got hot and there were no leaks.
And that’s when I heard the noise mentioned above.
This used to be the Daily Driver, so never pushed real hard or anything but bolt ons mentioned above. When it spun the bearing, I was already looking for a new Mazda 3 turbo, so I just speeded up the process. https://mazdaspeeds.org/index.php?threads/wastegate-duty-cycle-not-effecting-boost.16023/
Now I am trying to get the Speed3 back on the road.
DTC's: (please include descriptions) P0172 "System Too Rich (Bank 1) Working on that
Modifications:
Autotech Fuel Pump Internals
Cobb Access Port, airbox, Intake, Downpipe.
Corksport Recirculation/Bypass Valve, SS Exhaust Manifold, Boost Control Solenoid, CST4 Turbo, Rear Motor Mount, Injector Seals, Front Sway Bar
CPe Top Mount Intercooler, similar to the Corksport Top Mount
Large hood scoop
2.5 from 2014 ford Escape with 2.5L Duratec "Long Rod" and piston kit and total seal rings, 9.5 compression from Esslinger.
ECU/Tuning Software: Access Port V3
Tuner: Yours Truly (currently using stage 0, with zero waste gate, running rich)
Is the concern intermittent? No, It is consistent at RPM
Recent Repairs: Replaced Cylinder Head, with the engine in the car
Correction: Evaluation and measuring, good Vacuum, will get a compression test soon.
Also include logs of the issue
I am going to upload video and logs sitting in the driveway, I keep getting a security Warning when I try to upload the other video's, not sure why yet, might be size.
Mileage: 162217
Modifications:
Large hood scoop
![20250511_132405[1].jpg 20250511_132405[1].jpg](https://www.mazdaspeeds.org/data/attachments/31/31962-afcdf75c22395c71302fcca6b8fab55f.jpg?hash=r833XCI5XH)
