jacquet aldric
Hi, i have a problem with my cx-7
it don't start at all, it cranks normal, start for 1 or 2 seconds, then stall...
if i unplug maf sensor, it is starting but idle raise UP and down, and afr is 20-22... :-( stft AT 0
if i turn it off, plug black the maf, and restart, sometimes, it runs, but impossible to rev, afr at 20-22 and stft at +25..
when running without maf sensor, there is missfire, rough idle, and vacuum is Bad... -0.1 to -0.3 bars, normale it was -0.8 bars at idle.
if is rev it near 3000rps, then the vacuum goes black to -0.6 bars -0.7 bars, and then the motor run good, afr goes to 15, and no more missfire...
so i thought about vacuum leak? but Nevers found any.. AT idle with pressure and smoke machine, and also soapy water, also sprayed brake cleaner everywhere.. no reaction...
if i spray a little brake cleaner in the intake, the car run fine a few seconds..
i also notice that when i am a 3000rpm with afr good (15) , if i try to give gas, it revs good, but there is not a lot of boost, it raise to 0.4 0.6 bars, instead of 1.3, but i know that in neutral Gear, it never built boost like when rolling... (sorry for the pressure in bars, i'm from France.. but there is not a lot of 2.3 disi here ..son i try to ask to the best Mazda owners... i do my best to write not too Bad...)
i replaced maf, Map, inkake manifold gasket, throttle body gasket, all clamps on intake hoses including the turbo ourlet one..
checked all hoses... replaced pcv valve, i'm on it for 3 month... i'm going mad...
do you have any Idea?
i thought about buying a set off Cooper injector seals... corksport
but could that be an injector seals problem? that is leaking and throwing air into the cylinder,. i'm not sure, because when i throw brake cleaner on the injectors, it dont make the idle better or reving..
if you Can please help me...
best regards..
al
best regards..
al
