jsilva
The ongoing saga of my Speed6...!
Yesterday I replaced the fuel injector wiring harness and PCV valve (this is connected to my P2138 thread in terms of why I replaced them though not related in terms of the problem).
Now my Speed6 won’t turn over at all. The starter works, it’s just failing to start like if there were no fuel. This morning I went back in to see if I didn’t connect something and the only thing I found is that a gasket was out of place and possibly blocking some pins on the connector from the injector wiring harness. I put it back in place and no improvement. I had tested the wiring harness for continuity between all of the corresponding pins before I installed it.
The engine was starting before I replaced the 2 parts, and as far as I can see everything is connected as it should be.
Any tips would be appreciated...!
