Why do you feel that you need long tube?
1 not true1 Better flow and
2 less risk of failure. From the dp to the mid pipe.
3 still need my 2nd cat.
In my state, I still need to do emissions so I am not able to remove it. The cat on the dp can be removed.
Based on my experience, the increase in flow can cause the gasket to leak over time. This is why I like the long tube option. More joints equals more problems
The second cat is u monitored and will not throw a cel when removed but you will fail a visual inspection the first cat is monitored and will throw a cel
If you need to keep a cat then just put in a test pipe and call it a day a catted downpipe isn't worth the hassle and cost
Please just accept that you know nothing and that everyone in this thread is trying to help you and is far more knowledgeable than you.I dunno if can eliminate the one on the exhaust.
Your first posts say egr delete. Also mentioned obdll, if they use a scanner to validate run cycles the removed ecu points will come back during scan. Now your talking about visual inspection to fake out tests. You need to find specific answers to exactly what your state requirements are. Any tailpipe sniffing with a tester.. You will never pass. I've had better (CA smog before I moved) but non CA complying equipment and was told by a great test tech "I can't see anything different from stock, it can look like just installed. A test tech in CA has the smog machine go through a menu tree for tech to sign affirmative for the individual equipment. Your state maybe different, but you need to find out. If you fail, that knowledge will be added to your states database so best to get your facts first.
I never claimed that I know more. Basically, my issue is to try to be compliant as possible. The issue is by eliminating the cat, I no longer will be able to pass. Just being realistic. I don't want to have to swap it out every other year.
What I am trying to achieve the following.
I want to have a 1 piece dp. By eliminating the cat, the hope is to improve the flow. I've been looking into the cp-e qkspl long dp. Question is, it will eliminate both cats. Though I want to use a high flow cat. As long as I have 1 cat, I should be good.
