How dirty is your air cleaner?
Weird actually.... it's metal? or feels metal at least. I usually clean it with degreaser, then soapy water, then rinse it off and let it dry for at least 24 hours before using it. It literally looks like a cone filter, just metal.
Do you have a muffler at all? If any of the converter material fell apart while the engine was running it is possible that it shot back into the muffler or a bent section of exhaust where it cant escape causing a restriction
If that is the case, i will unbolt the rear of the downpipe, and hold it up with some sort of tie, and see if i build boost like that.
I removed my intake manifold to check on my injectors, and there's about a cup of oil in my IM. i removed and cleaned it less than 500 miles ago, and there was so much oil in it. My injectors have so much oil around them too, my seals failed for sure, there was also a small puddle of oil/gas under my first injector.
I have never sent these out to be cleaned, i have 2 sets. OEM, and some that came with a used fuel rail i purchased. I am going to get a set sent out and cleaned.
1. Catalytic Converter - gone. Problem still persists.
2. Injectors - working on this...
