Enki
Motorhead
Pull this nut, remove that heat shield tab from the stud and gently press it back towards the cabin (away from the motor; resting the shield on the stud itself will suffice). This will give you just enough room to remove the downpipe without having to fight too much.
The last time I employed this trick, three people had fought for over an hour to get it out (I was working on other stuff), and when I pulled this nut and moved the shield the downpipe fell off and on the ground. Figuring it out myself took over 3 hours the first time. Aftermarket downpipes tend to be quite a bit easier.
