Well I have been gathering my parts for a while and finally getting started on assembly. I’m really wanting to hit 600. Here’s what I’m using.
Corksport CST6
Manley H Tuff rods with arp2000 bolts
Manley Pistons with .250 pins
L19 head studs
ARP main studs
New Mazda oil pump and water pump
JMF v2 manifold
Corksport 3.5” intake
Ported head with +1mm valves
Corksport exhaust manifold (if it ever comes off back order)
King tri metal main bearings
ACL rod bearings
Cometic head gasket
Kelford 247c cams and springs
Hellcat fuel pump
Corksport throttle body
I have the corksport FMIC now but I know it will need upgraded. Just not sure yet what to use.
Still trying to figure out what clutch I’m going to use, what DP (running the Cobb currently),
I’m also running the Cobb catback. I’d love to keep the catback because I like the sound of it. Anyone know if I can use that exhaust for this build and still hit my power goal?
Also looking at the Bosch 95ib 1000cc injectors from summit racing part# DWK-17u0000954 anyone know if these will work with my set up?
Looking at the AEM 25-305bk fuel pressure regulator. Anyone know if this will work?
I’ve had the injectors and regulator in my cart for a while but afraid to place the order because I can’t figure out if they’re what I need or not. Needless to say any input on these parts would be greatly appreciated.
I’ll post pictures as soon as I get that figured out
Corksport CST6
L19 head studs
ARP main studs
JMF v2 manifold
ACL rod bearings
Cometic head gasket
Hellcat fuel pump
