Hellcat Fuel pump basket
Maisonvi
Grass-Roots Vendor
@JohnnyTightlips is going PI and wanted to upgrade his fuel pump. Ended up sending me the parts to make him a basket set up like I had back in my speed. Keeps the pump on the bottom of the basket to avoid starvation (I never had an issue). Stock line is used as a return and in this case an 8an feed line (mine was 6 an).
This one just needs the fuel safe heat shrink to get in and should be good to go.
Let me know what you all think
20200220_133206.jpg 87082483_613121896191105_7902712521532899328_n.jpg 87410387_2541418912635001_4161459341410435072_n.jpg 20200221_161640.jpg
Isn't that going to crush/kink that supply when it compresses down into the tank?
It compresses a way when installed.
Yeah have been meaning to update this. We adjusted the design to make it so the pump was always at the bottom of the basket no matter where it what. Hopefully this will solve any fuel starvation issues.
How big where the corrugated lines? There are a couple of choices 8mm - 10mm
Are you looking for just the holder? the whole pump basket swap? or the holder, hose, fittings and what not?
Install I can do myself,
just wanting the holder,
so I dont have to rig it and risk it failing.
And maybe the style of hose used, I know what it looks like but is it just corrugated fuel line?
Yep, uses submersible rated fuel line, a 6an bulkhead fitting, fuel rated shrink wrap for the wires and then my holder.
I found everything I needed, but can I purchase one of your holders from you? Just need to know how much and where to send you money lol
