How To: VTCS Delete Relay
bdubs802
I don't believe this has been posted here yet, not that I've found at least. The only information is scattered and not very clear so I felt like more detailed pictures might help with a step by step. This relay should be clear any codes related to VTCS allowing you to remove the plunger and solenoid.
Required parts:
I used a Voxx 8617 relay from best buy (8616 should work as well) and a 1 A diode
Soldering iron/solder
spade terminals both male and female
1. Cut off brown lead of the relay, this is not needed.
s!Ai0gHkiJX17dgeMV63zzmEs9lDKOpA
2. Crimp your spade terminals to the red and black wires, I put the female ends on here.
s!Ai0gHkiJX17dgeMTxSZMd05ItA3Flg
3. I then took cut a small opening in the wire insulation on the red wire to expose the copper. Solder the diode on to the wire like this. Polarity matters so pay attention.
s!Ai0gHkiJX17dgeMUMqr_QJp4rGqpHg
index.php
4. Do the same for the black wire.
s!Ai0gHkiJX17dgeMRUExiTBxkznPK0g
5. Heat shrink or wrap with electrical tape.
6. Cut the plug off of the plunger that senses if the valves are open or not. (not the one from the harness leave that on the car.)
7. Solder that plug onto the orange and yellow wires from the relay, polarity does not matter. Heat shrink or electrical tape again.
s!Ai0gHkiJX17dgeMPhJso7uWZ7hZU_A
8. Now go to the car and cut this plug off, this is the plug that goes into the VTCS solenoid, the black box on the intake manifold.
s!Ai0gHkiJX17dgeMQQqSbGkFGD7aSxQ
9. Put your male spade terminals onto these wires
s!Ai0gHkiJX17dgeMNAmKcZQeyblKuSw
10. Now plug everything in:
Red wire from relay -> Green wire on harness going to solenoid
Black wire from relay -> Black wire on harness going to solenoid
Orange and yellow should just plug straight into the matching plug where the plunger originally went
I've had this for a few hundred miles and the light has not come on once. Just tuck everything out of the way and you should be good to go.
Thanks for putting this together, as bunny said please upload pictures directly here using the upload file you can then insert them online as full pic or thumbnail.
Thanks for the write-up bt the pictures aren't showing. Upload them to this website
Oops sorry first post here. I had a feeling that wasn't quite right, should be fixed now though.
I am not against this solution either. I want whatever works the best and is most reliable.
I ended up breaking mine which is why I went this route, also a little cleaner solution since the relay is much smaller. I've run it for a few hundred miles now with no problems.
Spot on with the wiring directions. Just wanted to add there are diode protected relays that can be used as well. Obviously they are polarity sensitive. The one pictured here requires positive to be on terminal 86 and what I assume is the same for any other diode relay; they probably share standardization. Can also just look at the diagram and make sure the diode is pointing towards the positive wire when plugged in.
Used the OEM sensor wire clipped from the intake manifold and aftermarket automotive 2 wire connector for the signal/solenoid wires.20260514_144207(1).jpg
Used the OEM sensor wire clipped from the intake manifold and aftermarket automotive 2 wire connector for the signal/solenoid wires.View attachment 34532
How's this working out for you? I just installed my kit and I keep getting p2006 vtcs shutter valve stuck closed code. I'm running the jmf manifold trying to pass emissions.
