King Crow
I’m having what seems to be a very common issue talked about here but I have searched for several days to find a fix an I can’t seem to find anything that helps
Some background, I’m a mechanic. I’ve been working on cars for a few years now at a shop an know about engines an how to solve issues an nothing I can think of will resolve my issues
Issues: I’m having two issues that I just do not understand. 1 whenever starting my car it seems to have a long crank unless I prune the fuel system so I can assume it’s a fuel related issues mainly the injector seals. No biggie. How ever the next two I can’t figure out
2nd issue is at idle regardless of hot or cold. In the morning or afternoon the car sputters at idle with no real reason. No kr no misfires I can monitor even with an Apollo D9 scanner. It only throws codes during the third an last issue.
3rd issue is my big one. During any hard acceleration where I make more than 10 or so psi the KR as monitored via V3 AP shows upwards of 3 to 5 kr. It does also randomly through a misfire code or pcm comm code an I can’t figure out why. The car has fresh plugs properly gapped to cork sports rec .026 the coil picks replaced. No fix has been found. There’s no fuel issue I can see. The fuel pressure is optimal. The LT is good I think. I’m not a tuner so idk what great is but I know it’s not bad. The car is completely stock. 100% untouched. The only mod it has is the hpfp from cork sport an a brand new vvt/timing chain an washers which I did my self right after purchase as it’s at 100k an I don’t want no BOOM just the ZOOM.
Will be adding 2 data logs of 3rd gear pull 3k to 6k an two of just idling. Should be clear which is which
Im just looking for some peace of mind or maybe someone to just tell me “get a proper tune!” Comment even though the car is running stage 0 or stock map.
