Jok’air
Good morning,
I am writing this post today because almost everything I have tried to fix a mazdaspeed 3 2007 issue has been unsuccessful.
Regarding the car mods:
Long corcksport stage 1 engine block
turbo k04
fmic jbr
3 inch jbr intake
3-way corcksport solenoid
full decata
For over 2 years my car has not been running well. Almost all the sensors have been changed, map sensor, crankshaft sensor, turbo, boost leak test, compression test, internal tank pump, hpfp pump, at least 20 different maps etc ...
I have attached a journal to this post.
Currently I am in e50 mix mapping.
As soon as I accelerate the car jerks the revs are not clean. The duty cycle injection is very fast to the max even with pressures of lower k04 I had a gt28 with 18 psi it was the same.
I have maf to wot values which are similar to gt28 pressures. The mafcal has been done several times but the values are constantly moving. Has this ever happened to anyone? I am not very comfortable on the internet but I despair if anyone has a research lead I am interested thank you in advance.
turbo k04
fmic jbr
3 inch jbr intake
full decata
