tarnumf
Couple weeks I've cleaned my intake valves, after ~60k miles from previous cleaning. Had EGR delete and OCC for all these 60k, but I think my old OCC sucked.
Now I got DIY one, 5 good lbs of brass and copper and switched to CorkSport "check valve less" routing. Will keep an eye on this sucker..
So, here are my observations and pictures:
- if you do not have access to the compressor that can make 90+ psi continuously at CFM rate necessary for blasting gun, then forget walnut blasting and go straight to manual scrubbing. My 8 gal HF compressor sucked and eventually broke.
- for manual cleaning you will need 6 piece pick set, clamp pliers, tube brush, can of engine cleaner, roll of paper towels and some compressed air to blow that shit from runners.
- get rubber gloves on and use all your patience. This was the most boring work I ever did on the car.
- soaking doesn't do much, scrubbing does.
- put oil dip stick back when you turn engine to close next pair of valves or it will spit the oil out.
50k in 2012 (walnut blasted with decent compressor):
110k in 2016 before cleaning:
110k in 2016 after manual cleaning:
