Hey guys
Backstory: Last year I had a wastegate failure on my car and the symptoms of a blown head gasket. The coolant temp would rise very quickly, the motor did not want to build boost. The seals in the CHRA blew and the turbo must have cooked when the car was parked. (Drove to destination without issue, when I restarted the vehicle to leave a few hours later the turbo was grinding). Other than the jacked up turbo and cooling issues, the car ran totally fine under vacuum. Oil pressure was good, and so was vacuum.
Anyway, got the turbo (GTX 3076) set up with a new CHRA, and got everything to replace my headgasket. Having all of this time on my hands, I got back into the project. The headgasket didnt look too bad, but knowing that looks arent everything, I replaced the HG and put the motor back together. I was very meticulous about making sure all my T's were crossed and I's dotted.
Since I had to take the timing cover off, the car sat without oil for a few months. Thinking some contamination to the system was possible over this time, I filled the car with high mileage 5w30 for the first start, let it idle for 10 or 15 minutes, then drained it, change the filter, and replaced with Rotella T6. I have no leaks, everything runs good, sounds good, feels good, drives good, etc. But for whatever reason, I am getting oil pressure as low as 10 psi after 10 miles of driving. On a cold start, I am only seeing a maximum of 56 psi.
What I've tried: I swapped the prosport electronic sender out and replaced with a cheap mechanical oil pressure gauge. Yep, same pressure on both gauges. I even tried to stall the car when the oil pressure was low and saw as low as 8psi, but the factory oil pressure light did not flicker. I understand that it could be mains or the oil pump, but both of those only have 10k each on them. During the repair, the only things that were changed on the car were the oil drain line on the turbo (not leaking or pinched), full EGR delete, and the radiator.
I want to get this remedied, but before I get into replacing pumps and bearings, I want to make damn sure that I have checked anything else that it could be. I am going to drain the fresh oil again and see if there are any flakes in it, and maybe take off the pan and see if I can find any clogs in the oil pickup line. But, I just really do not want to swap out bearings and a pump just to fire it up and see that I still have a pressure issue.
Any suggestions are very appreciated. Thanks!
