Awafrican
Moderator
90c is toasty sure but in these cars rad fans don't even kick on until 98c.Hi, I know the thread is old but I am hoping that someone will still respond.
How were you able to run the sandwich adaptor plate because the MS3 uses a cartridge style filter and I am not too sure whether these can work with the sandwich adaptor plate as the screw on oil filters work. I am also experiencing low pressure when the heats up and is left to idle, the oil level indicator even comes on. But while the coolant temp is below about 90 degrees celsius there is no oil low oil pressure warning. I have to keep the car idling at 1000rpm for the warning to go away so I think maintaining lower oil temps will help me.
Thanks
Also the 2010+ models come with spin on filters you can buy the filter housing and put it on the earlier models. To be able to run a spin on filter and sandwich plate.
https://edgeautosport.com/mazda-oem...azdaspeed-3-2007-2009-mazdaspeed-6-2006-2007/
As others have said I do not believe it to be a temp issue at the temp you're seeing as that temp is fine for the speed. You're probably getting lower on the oil viscosity and something is up with the oil pump area or the pump itself that is letting the pressure drop.
