bRitzCrackers
I still have that Sparco bucket and mount if you're interested Ken
I had a belt shred from the tensioner pulley on my car having a bad bearing
My last track day I some how shreded my serp belt. Replaced it with a new one and noticed some grooves forming in it again. Didnt see anything touching but @Sho (I think it was him) suggested it might be my idler pulley. Well he was 100 % right. The thing started making a ton of noise the next day.
Went to get it off and it was STUCK for sure. After trying to be as careful as possible, I rounded the fuck out of the head of the bolt and spent almost 2 hours carefully grinding the head off and then removing the stud with vice grips. Im putting an idler on from my spare motor, but Im debating on ordering a $35 gates one, or just making my own (because why not?) Either way, back together (again) for the time being.
Really put be back on tuning my new injectors. I have a track day Tuesday so I have to swap back to the old injectors to run there, and then back again to start the tuning process. Super annoying.
I had my tensioner pulley take a shit on me too around 50k, it froze up and the belt shredded leaving me stranded on the highway, fun times lol...
Edit: I did replace mine with the gates brand tensioner, because cheaper and why not?
#NeverDoneModding
Koyo Rad install isn't too bad if the front clip is off the car. We did mine when my motor was out. Deleted the ac condenser (because racecar), then slid the stock Rad out of the support and the koyo in.
A "velocity stack" won't get you anything per se beyond the increase in area. If you made the pipe bigger by the amount of the stack leading the air in, it would get you more than keeping the radius. You don't have a low pressure area at the back end of the pipe so it's not the same situation as a carb but I think that, up to a point, having a bigger forward-facing opening will help ram more air down it.5. Brake ducts. So far I have made my duct tape mock up on one side. Not sure if I need to make some sort of velocity stack for it?
Yeah, when I eventually make the whole foglight housing a funnel to the tube that will be better. This would be more for a smooth transition of air if anything. Probably not worth the effort thoughA "velocity stack" won't get you anything per se beyond the increase in area. If you made the pipe bigger by the amount of the stack leading the air in, it would get you more than keeping the radius. You don't have a low pressure area at the back end of the pipe so it's not the same situation as a carb but I think that, up to a point, having a bigger forward-facing opening will help ram more air down it.
