Mastermind46
Sooooooooooo coolant lines... the metal hard line that the turbo return tees into failed. It has a nice hole rubbed in the side of it due to the turbo sitting against that metal tee. I didn't think it was sitting against it tight enough to be an issue but I was wrong. I will need to figure out what to do as that hard line is not really movable.
I am thinking of removing the hard line completely and replacing the it with brass tee fittings (2 of them, although one of the tees is for the throttle body coolant return which has been bypassed so I may just cap that off at the feed side) and silicone hose all the way to the oil filter housing.
Anyone replace that coolant return hard line before or have any thoughts on replacing it??
