Mastermind46
I don't cross thread... I just forget to threadJust wait until you find out all of the suspension bits were cross threadedb back together.
Sent from my SM-N960U using Tapatalk
Sent from my SM-G950U using Tapatalk
I seem to remember cross threading on my car and in lbs being tightened to ft lbs on another.I don't cross thread... I just forget to thread
Can't wait to see the track time progression as you get the suspension and tires installed and setup. Are you going to do everything at once or 1 at a time?
I was expecting something else when I saw white line shipment....Whiteline shipment arrived today
He has a very persuasive mouth. He convinced them to start making it again.Where did you find the gen2 AntiLift Kit? I was under the impression that whiteline stopped making them.
I know whiteline made one for the gen2, but I know they stopped for a little while.
Anyway... the reason I ask is that I have a set of control arms with a gen1 kit (not installed yet) and I have a gen2. The bushing that mounts to the subframe is 1.5" tall (gen1 subframe is 1.5" thick at the control arm mount), while the gen2 subframe is 2" thick. (My measurements could be off, I'm going off of my memory.)
A die grinder will fix it, I just decided to lower it on my priority list for now. Not sure if there are any other mounting differences, but the height difference in the subframe is due to the FSB mount change from stand alone straps to the control arm bolts.
Not sure if they revised it, or decided to include spacers or something.
I'm going to tackle that project in a month or so. I will keep you informed if I get to it first.
Forgive my grammar, I had a long day at work.
Next weekend, right? I'm preparing the lube as we speak.All good, I’ll be doing the install hopefully in the next week or two. I’ll report back what I find
