NinjaCustoms
New update on CX-7,
I found some time to work on my car and big suprise its not about tuning this time. This time i collected some tools and prepared for the ,,big cleaning,, of something that is the most painfull experience of all mazda owners and it is RUST. I began with ordering every new parts such as coolers condensers oil bushing ect. which turned out not cheap.
I nearly disassembled whole front of my car and im moving slowly to the back.
At this step I have ,,clear engine bay,, where i took everything out replaced engine mounts , cooler , condenser ,all kinds of rubber and belt and even all fluids. I sanded down all metal elements removed during the process , i've put zinc layer and anti-corrosion paint which ll be painted black as a final step.
Tommorow i'll apply r-stop protective layer and final black coat.
Next I'll move underneath and disassemble whole suspension and everything in way to the body. Then sand down the body and repeat my ,,cleaning layer sequence,, which is zinc layer , rust-free primer ,protective coat of app's r-stop and black paint which is coloured as body and if its not major suspension part i also spray it with extra protective bitum-mass layer.
The only photo i have except disassembly photos i use as my ,,hov to reassembly,, 'll be posted down.
SPOILER : this photo was tahen half through the job and does not represent all the hard work i've done,
Wish me luck and motivation.
