Barett@ContriveDesignInnovations
Grass-Roots Vendor
Mazdaspeed 3 & Mazdaspeed 6 - Billet Thermostat Housing
Pre-Order - ship date ~April 20th or sooner Billet Aluminum Thermostat Housing Mazdaspeed 3 & Mazdaspeed 6 Upgrade the plastic OEM thermostat housing with a precision CNC-machined billet aluminum replacement. Designed and manufactured by Contrive Design Innovations, this thermostat replaces...
contrive.design
Mazdaspeed 3 & Mazdaspeed 6Upgrade the plastic OEM thermostat housing with a precision CNC-machined billet aluminum replacement. Designed and manufactured by Contrive Design Innovations, this thermostat replaces plastic, give you optional AN compatability & clearance for Mazda 5 alternator setups.
The result is a easier, flexible, and cleaner solution for Mazdaspeed cooling systems.
CNC Machined Billet Construction
- Precision machined from 6061-T6 aluminum
- Optimized design provides clearance for Mazda 5 alternator without modifications
- Hard Anodized maintains black finish
- Designed specifically for Mazdaspeed DISI MZR
- Reuses factory mounting locations, hardware & hose connections
- No modifications required
- Standard Threaded for ORB Connections
- Barb connection swappable with AN falred flange
- -8 AN & -16 AN Threads
- Hard black anodized finish - won't fade
- Lightweight motorsport-inspired design
- Subtle Contrive logo etching
