Mazdaspeed 3 & Mazdaspeed 6 - Billet Thermostat Housing
Pre-Order - ship date ~April 20th or sooner
Billet Aluminum Thermostat Housing​
Upgrade the plastic OEM thermostat housing with a precision CNC-machined billet aluminum replacement. Designed and manufactured by Contrive Design Innovations, this thermostat replaces plastic, give you optional AN compatability & clearance for Mazda 5 alternator setups.
The result is a easier, flexible, and cleaner solution for Mazdaspeed cooling systems.
CNC Machined Billet Construction
  • Precision machined from 6061-T6 aluminum
  • Optimized design provides clearance for Mazda 5 alternator without modifications
  • Hard Anodized maintains black finish
Direct Bolt-On Replacement
  • Designed specifically for Mazdaspeed DISI MZR
  • Reuses factory mounting locations, hardware & hose connections
  • No modifications required
ORB Connections - AN Compatibility
  • Standard Threaded for ORB Connections
  • Barb connection swappable with AN falred flange
  • -8 AN & -16 AN Threads
Clean Performance Aesthetic
  • Hard black anodized finish - won't fade
  • Lightweight motorsport-inspired design
  • Subtle Contrive logo etching
I'm curious, what is the purpose of running a Mazda5 Alternator? Less drag on the engine or more output?
If you delete the AC compressor you can use a mazda5 alternator in it's place to get the stock one away from the turbo and free up space.
Has anyone swapped out the OEM thermostat for one of these yet?? Just curious as to thoughts on it, I'm currently getting a P0128 CEL and will probably be replacing the T-stat soon
2011 MS3
2011 MS3
Not yet, first batch should be shipping out soon. Be a perfect time to grab one and install since you're changing the t-stat anyway.
