Mazdaspeed 3 & Mazdaspeed 6 - Billet Thermostat Housing
Pre-Order - ship date ~April 20th or sooner
Billet Aluminum Thermostat Housing​
Upgrade the plastic OEM thermostat housing with a precision CNC-machined billet aluminum replacement. Designed and manufactured by Contrive Design Innovations, this thermostat replaces plastic, give you optional AN compatability & clearance for Mazda 5 alternator setups.
The result is a easier, flexible, and cleaner solution for Mazdaspeed cooling systems.
CNC Machined Billet Construction
  • Precision machined from 6061-T6 aluminum
  • Optimized design provides clearance for Mazda 5 alternator without modifications
  • Hard Anodized maintains black finish
Direct Bolt-On Replacement
  • Designed specifically for Mazdaspeed DISI MZR
  • Reuses factory mounting locations, hardware & hose connections
  • No modifications required
ORB Connections - AN Compatibility
  • Standard Threaded for ORB Connections
  • Barb connection swappable with AN falred flange
  • -8 AN & -16 AN Threads
Clean Performance Aesthetic
  • Hard black anodized finish - won't fade
  • Lightweight motorsport-inspired design
  • Subtle Contrive logo etching
