chris' speed 3
So I’ll make this short, 2013 speed 3, 144k km. Just got a new ecu for an injector problem now I’m getting 0 fuel pressure
EDIT: for anyone diagnosing fps issues, brown wire is ground, white w/ green stripe is the output signal and yellow is the input signal (5v)
p0089 and p0192
engine starts sometimes then dies minutes or seconds later. Or doesn’t start at all and jsut turns over also tries to start when I have my gas pedal to the floor which is weird
I checked wiring I have 2ohm on 2 wires at the connector to the fp sensor and the peachy wire has closer to 5ohm. There’s a weird blue liquid in the connector I’ll post pics
I hear the ITFP prime and I disconnected the fuel line going into the HPFP and put a water bottle and fuel was in it when I primed so ITFP is good
here are the pics
appreciate the help guys
p0089 and p0192
here are the pics
