My Auction Mazdaspeed
I would also fix all the things away noted before fooling with a tune or log since they clearly leak
One of the unlisted issues is that I don't have plates for it currently (waiting on title), so most everything that can be fixed without too much moving will be done first. So I'll be doing all of this, fluids, and plugs before moving it again. Once those are done I can justify the risk to get logs.
Thankfully I live on the edge of town so plenty of backroad access to test on, just no sense pushing my luck until there's a good chance for progress. I do appreciate the insight, though. Thank you all for your help.
I'd bet you have an air leak time for a boost leak test what's your ltft (long term fuel trim) at idle and cruise ? should be less than +/-7 ideally +/-5
https://mazdaspeeds.org/index.php?threads/how-to-build-and-perform-boost-leak-tester.8853/
also looks like your valve cover breather hose onto the intake isn't actually fully connected, circled for youView attachment 30926
also looking at your bov it looks ike that flange onto IC isn't fully aligned I wonder if that's leaking too. no zip tie on the small hose coming off bov another potential leak under boost man that T for the boost gauge is a hodge podge job
Got a chance to mess with it again briefly tonight.
The breather hose is definitely as seated as it can be. The tube from the intake is seated deeply near the joint on the piece it clips to. It definitely does look weird, though.
The BOV was misaligned, and held on with two different bolts no less. I loosened it a hair and was able to line it up much more cleanly.
I added some coolant and started it up to make sure that was still a thing it did. It did indeed, and ran pretty much as it was. Now that I was able to listen to it run from inside the bay, she sure doesn't sound super healthy. A little ticking noise can be heard from the intake side, and a bit of a rattle from the belt side. Going to do a compression test soon and see how it reads. If it's somehow good, I'll do oil and track down the rattle. If it's not good, I can acquire a JDM engine about an hour from here for $1700 with just under 60k on it. Maybe that's a route to consider before tearing too far into it. As always, I'm open to suggestions and feedback. Hopefully will have more updates soon.
The ticking is normal. It's the direct injection injectors firing
@Raider hates jdm motors
Oh good. Hopefully the rattle is just something trivial that worked itself loose and we're good.
Why the hate for JDM engines? From what I've seen they are generally better maintained and pretty reasonably priced. Granted, I'm woefully unfamiliar with Mazdas in general, so maybe there's some good reasons to hate there.
Thanks for the heads up on the injector noises. That had me a bit worried there for a sec.
Everyone knows JDM motors are a 75k mile 1 oil change motor in worse shape than whatever it is to replace.
Ah. I guess I've just seen people get fairly lucky on their JDM pulls. Most notably with Hondas, but Nissans as well.
Was feeling well enough today that I decided to go mess with it a bit.
I cleared the codes and checked some more of the settings in the AP and figured I'd see if it could idle on it's own for a few while I checked to see if I could log with the current tune on. And even though I cannot log without installing the device and getting a new tune, it actually did idle for about 10 minutes without interruption. I killed the AC and stereo and it idled at around 600 or so.
After that I gave it a little gas to see how it handled coming back down, and it did not like that. It didn't die, but it did drop low and struggle each time. No CELs during any of this.
I also checked the intake for cracking or any areas that could be leaking, and I did not find anywhere that looked to be an issue. I'll have to dig more when I have more time, because it's not easily accessible at the very back for a solid inspection.
I wasn't able to isolate where the rattle is coming from on the passenger side of the bay, so that's still a concern.
Need to get under and see if the downpipe has been done as well as check the HPFP upgrade. New plugs should be here today, so we'll see what kind of change that makes soon also.
Rattling from the passenger side might be concerning. Could that be a loose timing chain?
That was, unfortunately, my concern as well. I'm hoping to get to spend some time this weekend really getting into it, so hopefully we'll know soon.
You can check chain stretch at TDC, or pull valve cover and look for metal on metal contact signs on the valve cover.
edit: I think TDC. Probably wrong on that.
What condition is the battery in now that you have charged it? The idle dropping after a rev can be a bad battery
I'm glad you asked, because I had forgotten to mention I checked it. I tested the battery at 12.34 off and 14.32 at idle. I believe those numbers fall pretty close to correct give or take. Not an electronics expert, though, so I could absolutely be wrong.
Mazdspeed jdm motors are usually cx-7 motors without maintenance and have shit compression, timing chains about to yeet themselves, etc. Not worth it.
That said it almost sounds like your speed needs timing and vvt work.
Indeed. So it sounds like I'm likely in the same boat either way. So it seems my options may be to pull this and do the work or acquire a second and do the work while I limp this one around. I only have to drive like 50 miles a month, so if this makes it 100 I get 2 months to work on the other engine and my daily lol.
Hey I had some similar issues you described (misfire codes, lean at idle, etc) and ended up replacing the fuel rail pressure sensor. Technically, Mazda says to replace the whole rail, but I just replaced the pressure sensor and it's been fine almost 20k miles later. See this thread for the fix and PN.
https://mazdaspeeds.org/index.php?threads/solved-p0192-code-and-p0300-misfires.15964/
Thank you so much for this! I hadn't seen or considered that yet, so I will absolutely give that a shot.
Been a good long while since I've updated this thread, but that's because it's been just as long since I've even touched my 3. Health issues, life stuff, etc. kind of get in the way, I reckon.
That said, however, I've started working on it again over the last few days. New battery and oil change, then today I broke into the engine to check and see if the car had the HPFP upgrade done and to replace the plugs. Well when I pulled the plugs the middle two were rusted to no end. They came out just fine, which turns out may be a bad thing. Looking down through their holes I can see there is definitely rust inside the cylinders as well. I drove the car from where it's been sitting up into my driveway to work on it today, so it surprisingly still runs exactly as it did when I parked it around the time I made my first post.
I got the intake, battery, ECU, intercooler, and harness out of the way to pop the valve cover off and inspect further, but that thing is absolutely stuck. On the rear side I can see what appears to be some kind of make-it-yourself gasket squished out. I am assuming that is serving as an adhesive at this point and not letting the cover go. Before I start cranking on it to pry it free I wanted to see if anybody could tell me if there were any non-obvious points where the cover is attached. I hit all the screws on the perimeter of the cover, and the few in the center. There shouldn't be anything beyond those, right?
Also I wanted to get opinions on how screwed everybody thinks I am here. I'll see if I can get the picture attached so y'all can see what I'm talking about. The plugs are a rusted mess, and that carries over to the threads and holes they sit in. Hopefully the picture comes through well enough that you can see them.
