Duey1083
Hey everyone,
Tagging: @StreetSpeed6 @Awafrican @Enki
I've been trying to trace an issue with very negative fuel trims at idle, KR at WOT and pig-rich AFR conditions during WOT runs. A lot of these issues started happening after cleaning the intake valves and installing an OCC last March and can be seen in this thread (should you have time): Negative LTFT at Idle, KR at WOT | Mazdaspeeds.org, The New Era in Mazdaspeed, CX-7 & Ecoboost Forums!
Long story short, I took the car to a shop to check for boost and exhaust leaks. Two were found and fixed: first was the EGR (which was deleted) and the second was on the intercooler flange for the BPV and throttle body inlet. Other than that, no other leaks were found and my compression across the cylinders was normal.
I'm working with Stratified on a datalog revision and sent the attached datalogs into them for review. If any of you have time to review the logs to see if anything jumps out at you, I would greatly appreciate it. The biggest issue to note that I can see are the pig-rich AFRs, which go down to 8-9 halfway through each pull in 3rd gear. I've also attached my MAF Cal log and an Idle Log.
If it's not a tune related issue, I'm starting to suspect my primary O2 sensor is the culprit, but they're expensive and I would rather know before throwing money at parts.
Thanks in advance!
Thanks in advance!
