mspeedzilla
The fuse in the PJB (PCM) (thing under passenger side dashboard) is fuse #38 for stop and horn. Not to be confused with fuses #68 and #81 for the left and right tail lights. After checking fuse #38 check the fuse in the engine bay on the main block fuse. From there check your horn relay. If all else fails move on to replacing your clock spring and brake switch.
Brake switch here Part BN7N66490
Clock spring here Part BP4K66CS0
