Have you unplugged the ECU and plugged it back in
...LmaoHave you unplugged the ECU and plugged it back in
This could be a good thing to reset it all. I have heard of early on when the speeds first came out people had issues with it going into limp mode which I think is basically like what you're describingHave you unplugged the ECU and plugged it back in
...Lmao
Shit, it's valid.
Just cause wire resistance is in spec (should be less than 2 ohms) doesn't mean the wires are good.
They should be load tested with a head lamp bulb to see if they can carry enough current to light the bulb. Disconnect the ECU connectors and injector connectors. Connect a headlamp bulb wire to one terminal and the other bulb wire to ground. Then take a wire and jump from the positive terminal to the proper ECU terminal for the wire being tested. If the bulb lights up bright then that wire should be good. Repeat the test with the other wires.
If all the wires can carry a load like that then the ECU is probably the culprit. The injectors all get their power from the same fuse and the ECU controls the ground side for each injector.
Glad you found the issue, and also sorry it is probably the ecu. Curious if a reflash from mazda would fix it. Might bs worth asking about it via phone or whatever with a local mazda dealership.I just asked him if he load tested the harness and he said he did it with his AVR and it checked out, not sure what AVR is tho
Prior owner might have tried to do guardian angel or wotbox or somesuch and fried the injector controllers. IIRC the injectors are peak and hold 700w @70V to fire and then tapers off after.
Lol. In before it's locked/encrypted with someone's tune and can't be reflashed.
Doesn't a new ECU have to be programmed by the dealer due to the theft protection shit
Also @Enki pretty sure you called ECU a while ago
My worm addled old man brain wants to remember something about there being an issue with the dealer trying to reflash an ECU that has some specific aftermarket tune on it, but I don't recall exactly what that might be.What?
There's no way I would call an ECU fault that fast, so I went and checked. Was actually page 7:yeah he did it was on the first page pretty sure but there was no way for me to know that without checking everything else
Unlikely. Engine is wanting more fuel for the air it's getting, so either you've got an injector down (doesn't sound like it in the video) or a massive tear/hole/crack in something.
Not sure how your cat could instantly clog after doing the stuff you did to it, but did it start immediately after that? Did you do anything behind the engine at all (to the turbo/downpipe/etc)?
One thing about making good power again is it could be hard on a half good engine. Hopefully it works well for a while though!I mean properly firing injectors still won't fix poor compression or leak down.... This isn't you're only issue, albeit an important one
