chris' speed 3
Well sorry that wasn't the problem but you will be glad you got the dp eventually for sure. It is the best bang for your buck on a speed pretty much. It will probably gain you 20hp at the least.
Vtcs is deleted in my car and it has had ZERO negative effect on my car. I cold start my car in sub 10 degree weather and it doesn't do rough starts. Improves flow on your intake manifold and isn't difficult really. Takes about a day to do it and then you don't have to worry about it anymore. If you cant have a CEL though idk if it would be an issue or not.
Vtcs tumbles air through your intake manifold at low rpm (idle basically) so it being shut would definitely not let hardly any air into your engine and makes sense. Get that baby fixed and post a boost video! Lol
So the vacs control solenoid just wasn't connected I may have knocked it off when installing the downpipe but I put it back on and the code hasn't come back
Im at a loss, I don't want to keep dumping money into it I want to enjoy it. I did a compression test this morning and 180-165-160-140, yes this is a problem but it shouldn't cause this problem It should still be able to boost as i had done a compression test 3 months ago and it was 145 in cylinder 4 and its been boosting fine.
Its getting too much air or not enough fuel when I repeat the issue trying to accelerate, I have an extra set of spark plugs lying around so maybe Ill gap those and throw them in. I really don't know what to do and any help or guidance would be appreciated
before anyone tells me to check for vacuum/boost leaks, I have
@Enki @Awafrican @StreetSpeed6 @L337TurboZ please help me out
