Chemmedic
Hello all,
Long time member, but I've been inactive for the last while. I came into the hobby not knowing anything, still don't know much.
With the help of friends (@Awafrican) and this forum, I rescued (a shop rebuilt the engine) a 07 MS3 with blown o rings and a gouge in cylinder 3, and lovingly put the whole thing back together. It took me way longer to tune (Freak) it then I should have, but eventually got it done. This was back in 2016. Bear in mind, this car sits in storage pretty often, as I'm either away or just don't have time for it.
Full list of mods I won't get into, but the main ones are a GTX 2970 turbo, CS HPFP, Cobb FIMIC, Southbend clutch, CNT DP, plus some more supporting mods.
Fast forward to this past year, and I have noticed oil leaking now. Initially about 1 litre /oil change, and now more like 2. I can't find the source. I think it is the longblock, as it seems to come, not quite from everywhere, but several places certainly. At first I noticed some seeping from the valve cover, and I tightened that down and it was better. Pulled spark plugs and they were rich but tolerable. I've checked the compression, which I've been doing as soon as I noticed this issue, and I did find something. Compression is stable at 180 in cylinder 1 and 175 in 2, 155 in 3, and 170 in 4. I've had the chance to check this over several months wet and dry, and these numbers haven't budged at all. I has the idea to install a Kosmic Oil Catch Can, as I had foolishly neglected to properly vent, I had been running a JBR stage 1 can up to that point. I thought maybe block pressure might be causing the leak. Obviously it hasn't improved, the catch can does seem to be drawing off some fuel, but that's kind of hard to tell from the crap that comes out of there.
Overall, the car is running great. Cobb tuner gets me to an estimate of about 350 to the wheels, though I've never done a real dyno. I know the setup is probably capable of more, but I'm happy where it is power wise. I'm holding 24 psi, WOTs pull like a sun of a bitch, I'm actually scared to drive the car full tilt... I don't notice clouds of smoke, no rough idle, I would guess that I am burning some oil, but the spark plugs aren't fouled, and the tail pipe is not spewing carbon. I'm not seeing coolant in the oil or anything like that. I did see a residue of oil in my intercooler piping, but not quantities that had me worried.
So if anyone has any ideas, I'm open to listening. My main problem these days is I just have no where to work like I used to after moving to a bigger city. I'd love to pull the valve cover and start poking around, but I just can't do that where I live now. So I'll likely have to take it to a shop regardless. But I'd at least like to know what I'm likely dealing with so I know who I should take it to. I'm thinking it's head gasket. Hoping someone can confirm that.
