Reddez65
2007 mazdaspeed 3
130,000 miles
Cai, cheap-o dp/racepipe
Corksport tb
Tuneless
P0300 still fighting changed spark plg twice maf, map, ckp, cmp, new turbo, timing chain and vvt stuff and 02sensor, injector seals cleaned, battery, changed oil several times and motor mounts.
I just did a compression test 10 minutes ago 160psi all 4 cylinders. Spark test comes back good. Boost leak test passed.
Still fighting the p0300 stutter under load which anytime i punch it used to go into limp mode now the cel blinks amd throttle still pressed but the speed comes and goes and I can drive lkke granny forever but its like as soon as I give enoufj throttle for the turbo to start car stutters and cel blink. The only test I havent done is leak down but I was under the impression that if engine has compression in all cylinders there is no need for a leak down test.
THere seems to be a good amount of people kinda the same issues but 95% of posts I read on this problem nobody ever solves or they arent sharing.
Oh yeah I even tried replacing the ecu with pos company flagship -0.
130,000 miles
Corksport tb
Tuneless
