BoostFever
Year/Make/Model: 2011/Mazda/Mazdaspeed3
Mileage: 105k
Concern: Rough cold start and P0300
DTC's: (please include descriptions): P0300
Modifications: Stock
ECU/Tuning Software: None
Tuner: None
Recent Repairs: N/A
Correction: N/A
Hey guys, I've a 2011 Gen2 Speed 3 with 105k miles. I spun a bearing last year, due to low oil, and had my engine replaced. A very painful lesson very well learned. I supposedly got a "Grade A" engine with <45k miles.
Since it has been replaced I've had a P0300 error on cold starts but only when it's warmer than 19C / 68F. The start up is very choppy and cuts in and out until everything is fine and smooth. I've taken the car to AutoX and also a track day with a handful of 20 minute sessions at both. Engine ran perfectly fine.
So far I've replaced the coils with OEM coils and replaced the spark plugs with pre-gapped NGK plugs. But no luck.
I've scavenged old threads and have come up with the follow things to do next:
What else should I be doing? Is there something super obvious in that datalog?
Any help is really appreciated, I just want my old reliable speed 3 back.
Mileage: 105k
Tuner: None
Recent Repairs: N/A
Correction: N/A
- Check cylinder compression
- Clean MAF sensor
- Check for vacuum leaks (smoke test)
- Check / clean injectors (most expensive option for last)
