Hello, My engine has been running lean with high fuel trims, the LTFT being at 20.3 and STFT being atleast 15% or greater on idle. I looked over
https://mazdaspeeds.org/index.php?threads/raiders-p2187-on-a-2007-mazdaspeed-3.6984/
and decided to take it to a mechanic. They did a smoke test and smoke came out of the turbo intake boot (which they fixed), the EGR valve, VVT actuator to valve cover, and the BOV.
They said the BOV apparently had the biggest leak, not in terms of the vaccum lines, but its leaking at the BOV itself. Apparently, when they pinch the vaccum line on the BOV valve, the fuel trims fix themselves immediately.
I looked into this a little on my own, and online says that you cant exactly preform a smoke test for a BOV since its not in its running condition, or something of that sort. That being said, I was wondering if the BOV was actually the problem, or something else such as the BOV is not recirculating, or maybe something completely different. Please let me know any thoughts.
The mods I have on my car is:
AEM cold air intake
Turbosmart dual port BOV
I only have a basic OBD test tool so it might be hard for me to get data.
Thank you in advance
AEM cold air intake
