Post a Photo of your Car as it Sits Right now!
Spent some quality time... Was freaked when I realized after set (siliconed) cover in place... Wtf is wrong with this picture?? Then F.. K
I forgot to torque the intake cam/VVT bolt!!!
In the end was fortunate that pulled off cover wet silicone was still just fine..
Thought to post in real time... Much easier with no body in the way... But F.. K MAZDA for this BS....
I now feel the pain....Anyone who's clocked their turbo... GD this is not loosened bolts turn wherever and done... Decided that covering the valve cover with hot side pipe wasn't pretty...
I would hate to do within engine compartment. PXL_20211024_235327284.jpg PXL_20211024_235344127.jpg
Thought today was a easy install of fmic, as usual though.....while vender said just tug hard on PS cooling lines and install cooler in front of IC....right, not doing that so of course hoses disconnected and will properly bend metal hose angles to fit rubber hoses with no weird tension. Looking at the mount brackets vender supplies for IC... That needs to be done properly too... A future job. PXL_20211031_205608740.jpg
Well now happy with results. I wish I could weld a lot better than my abilities.. of course the length of beads put down by me is less than my height. One of those.....I need to practice tasks of my bucket list.PXL_20211104_223234314.jpg PXL_20211104_222801779.jpg
After plumbing in place. Where will OCC go? Left side is Corksport fuel tank. So a idea happened while I stared at this PS hose bracket for short metal pipe between tank and cooler...... will see if works out after road tests.PXL_20211106_213543448.jpg PXL_20211106_213548554.jpg PXL_20211106_234854649.jpg PXL_20211106_234910079.jpg
Currently. Refuse to give up...again
Sent from my SM-G996U using Tapatalk
Well as my previous post said .. wonder how long this marriage will last...the bitch did not like me lately...so here's "her" Valentine gift...
SOB her holes have to be exposed, darn rings seem screwed up...yeppyPXL_20220214_003950372.jpg PXL_20220214_003521112.jpg
Well looks like we're doing this again.... Lol Only time will tell what happened but hopefully motor is fine and the moolah will be in finishing my build finally.
We're doing it all right this time boys. Full blown and finishing the build!! Deep cleaning my engine bay at the moment in preparation for new everything lol
Just was walking from garage to house and sun was just right to show off hood fabric...car is chomping at the bit....500 miles more of plain dino oil before final break-in is done....PXL_20220501_004905085.jpg
Technically my sons, if he restarts paying..
08 85k speed 3 owned since new, dealer never serviced or needed. Redline only oil changes since break in. Valves at manufacturer max side of clearance, not over. Was a shock to take off tmic shroud, never seen underneath. Not used to seeing no abused connectors, wiring, zip ties, broken plastic bits. (Now have though)
Leak down @ 100 psi 1&4= 2%, 2&3= 1%.
VVT, valve timing path replacement. VVT was just starting to get play, no missing metal bits.
