It will go up to 2 or so then drop STFT are all over, LTFT are good to go.Ive heard of brake boosters causing a vac leak with a normal pedal feel.
Now to find that part number.Maybe your checkvalve on your brake booster line is bad. This sounds like the same thing I had when I uhhhh did that whole brake booster checkvalve delete because it was hidden inside of a line.
Boost leaks are simple: when you go WOT you hear a big "SSSHHHHHH!!!" and the actual AFR goes in log 9s or even 8s. It's not the case here and never was according to what we can see in the logs posted on the 1st page as well as in the logs here.My money is on boost leak...
Remember to use a lower gear and not go until redline... 2k RPM will be plenty to figure if it's all good.I'll try to get you guys a wot log today
I think it depends more where you have it... I had all kinds and the ones around the boost tubes (hot, cold, doesn't matter) were pretty easy to hear even if the boost was 1-1.5PSI off the target.@mituc You don't usually hear a boost leak unless it's pretty extreme.
Log 2 was actually better, went up to 6.3k rpm in 4th right at the beginning and the AFRs were perfect. the vacuum the engine produces after letting off also indicates a healthy engine (at a first glance at least).datalog 3 had some wot around the 60 second mark.
Finally have a moment to upload logs. Hope this can put in some insight.
