Ramps are fine, and actually preferred when torquing the rear endlinks.
Ahh I see you spelt white line wrong. Seriously though yes Amazon spoils us, $30 for the hefty bar actually doesn't seem too excessive.
I’ve had my white line bar on the car for a few years now. Any questions let me knowha! i was actually looking at white line as well. i don't know literally anything about them. i saw them mentioned here in this thread but i wasn't sure about them. i could do some more research. that bar may actually be a little cheaper. i guess the one thing is that the CS bar does come with the upgraded billet brackets (normally $80) so i suppose that's a good thing. likely i'm just being a baby.
i think i should do more white line research first.
So the included hardware is perfectly fine. 4 years now, MANY track days(probably 20+ track days) and NO issues. Fancy billet mounts in my mind are marketing BS. This is from my own experience of course.i'm not entirely sure what to ask i suppose. how are the brackets/bushings that come with it? i don't think it's absolutely necessary to get the billet ones. just a bonus i think. looks like the whiteline is nearly the same size as the CS. also i don't see anywhere the % of stiffness it adds. perhaps it makes sense that it's similar to others with the 2 hole adjustment (though i'm sure there is going to be some diff based on spacing). do you run yours on the stiffest setting?
also thought about getting a FSB at the same time...but maybe starting with the rear first would be a good first step.
Ive been running it on the softer setting. I tried full stiff for my first time ever back when i was a track noob and i spun out like 5 times in the same medium speed corner so after that i moved it to the softer setting. Had to adjust my driving style but i honestly love it. It made such a night and day difference to the handling of the car. This season as i up my power, i MAY move it to the stiffest setting for track duty but we'll see how the rest of my setup deals(alignment and tires pressures).
the whiteline bar is 27mm thick. This ive heard is kinda massive? not sure. but it works.
as for FSB...it will help some with body roll but it will also counter the effectiveness of the RSB. on these understeer prone cars FSB shouldn't really be considered unless everything else has been dialed in. and by dialed i mean DIALED. not the pep boys down the street did my alignment and everything's LITTTTTTTTT. That is not dialed LOL.
If body roll is bothering you coilovers that dont suck(there are options) will fix that without the negative impacts of FSB. just something to keep in mind. Jumping from basic ST coilovers to the Bilstein b16s did more for me then any other single suspension mod.
you will enjoy the sway bar. it is definitely a nice "simple" mod that makes a difference and honestly its just a stiff bar. as long as its not breaking or rusting i think theyre all very similar lol. I went whiteline because it was an amazon pricing error and i paid $145 CAD shipped via prime so i jumped on that lol. price went up to 300CAD immediately after i placed my order LOL.wow, thanks, man! good info. i might just pop on this one then. turns out it's like $3 more but all the free shipping.
i really don't even care which one i get, per se. i just want it to be a good one and a rear sway bar isn't something that someone buys every day or even for every car. my last sway bar was a front top mount for my beretta.i just want one that will be as reliable as possible. body roll doesn't really bother me yet but i would not mind having less of it. i don't track the car or x-cross so the only rallying i do is on entry/exit ramps typically.
i'm also adding some lowering springs which, i suppose, may help a little in regards to rolling but i have always assumed it's more for aesthetics. perhaps my next mod could be better struts/shocks. i doubt i will do coil overs. them bitches are pricey af.
thanks again for the good deets.
lowering spring will do more for looks...ride quality will probably take a bit of a hit though. Either way, for what it sounds like youre doing, a simple spring/strut combo with the rsb will be amazing.
